03 Jetta O2 sensor replacement
Old Nov 13, 2010 | 01:35 AM
piyush123's Avatar
Default 03 Jetta O2 sensor replacement
I need to replace the O2 sensor on my 03 Jetta GLS. I think it's located in the center-rear of my engine. Is this correct? Next, are there any special tools I need to replace it? Do I need to simply unbolt it from the engine block and replace it, or is it more complicated than that?
Thanks in advance
Old Nov 19, 2010 | 09:03 PM
Twoods12's Avatar
Thanks in advance
I couldnt really tell you where they are on your car but on my 94 gl there seen from under the car. Its the only wires comin from your exaust besides your egr which is on the back/bottom of your intake. All youll need is a 15mm maybe bigger wrench and be sure to un hook your o2 wire and reset your car. Just unhook your battery for the time you put the new one in. If you have a stock radio make sure you have your theft code to turn your radio back on.
Old Nov 19, 2010 | 09:09 PM
Twoods12's Avatar
Thanks in advance
Make sure befor you do it though cause times change from 94 to 03. They might be hard as hell to get to. Just incase i make myself look stupid. Is the gls a v6 or 4cylinder?
Nov 29, 2010 07:17 AM
cvdiehard
Feb 28, 2009 03:02 PM
Gearjammer
Jan 21, 2007 02:07 PM
brighteyes
Jan 14, 2007 11:46 PM
Timetogetill7
May 23, 2006 09:20 PM
