'03 Jetta 1.8T Manual Trans Issue
Old Jan 28, 2016 | 07:39 PM
Craigs's Avatar
Default '03 Jetta 1.8T Manual Trans Issue
Hello
No recent repairs on this car.
Owned the car for 50k miles of its 160k.
Approximately 200 miles ago, 5th gear became difficult to shift into. I think I had to kind of wiggle the shifter to get it in. When it got worse, it felt as if something were blocking the shifter from moving the last half inch of the shift; if I released the clutch, the trans would be in neutral. If I forced the shifter, even with clutch pressed, trans would grind. When I let the rpm's drop to <1k, it shifts fine.
3rd gear has started to have the same problem.
1st gear, since I got the car, always required that I slow down to 2mph or so to downshift into it.
Any thoughts? Likely culprit and how long does it have?
Thanks in advance!
Old Jan 29, 2016 | 07:42 AM
First job I would check out the clutch hydraulics.
Old Jan 29, 2016 | 08:19 PM
Craigs's Avatar
Thanks!
It couldn't possibly be a clutch issue since it's not in all gears; yeah?
Will update the signature after I poke around the car tomorrow
vwconfused
Aug 31, 2012 05:52 PM
chunks3141
Apr 12, 2009 11:07 AM
dawkid
Mar 5, 2008 01:43 PM
NickAburg
Mar 3, 2008 02:58 PM
dalpod74
Sep 7, 2007 06:28 PM
