00 Vr6... Code help
Old Feb 24, 2009 | 05:42 PM
johndemon's Avatar
Default 00 Vr6... Code help
Hi
I have heard lots of stories about the 02 sensors and bad cat converters on Jetta's and it is now my turn to suffer i suppose. I have a 2000 Jetta GLS VR6 2.8L and I got these codes from an Autozone scan.
P1103
P1196
P0134
P0420
I was hoping someone can help me determine what the problem might be.
Any help is appreciated.
Thanks
John
Old Feb 24, 2009 | 06:12 PM
dozanti's Avatar
Member
Okay there are a few possible problems. I too was getting a code which threw the engine light on. I had it read at autozone and it came up as (bad Cat). I replaced the Cat and the codes were cleared since i had the battery disconnect so that i could do the required welding ( so i did not short anything out ) . All was okay for a day and the light came on again. I then referred to the SMALL leak i had from the intake manifold to the cat connection. Before i fixed that i changed the thermostat as well as temp sensor ( sometimes if the thermostat is not letting the car heat up or the sensor is bad it will assume the car should be warm already when its really not throwing the code for the O2 sensor up) so after those two fixes i repaired the exhaust leak and I have not had a code come on since ( 2 weeks ). I am running the same motor and car only a 2001. Also check your battery strength with a tester. Sometimes in a newer cars ( sounds absolutely crazy ) if the battery is not at optimal strength it will send false readings. The CAT or temp sensor/ thermostat is more than likely the culprit. It only took me a few hours to change the cat and sensor/thermo. Also what temp are you running at ? After warming up the car should rise to 189-190 and stay there without moving. If it moves or runs cooler and the needle fluctuates indicating the temp is going up and down..... replace that thermostat and temp sensor immediately. If the car is not running 189-190 after running for a bit and staying there you can damage the motor over a shortened period of time. GOOD LUCK hope all goes well and you can resolve your issue. Any questions ask for sure !
Old Feb 24, 2009 | 06:14 PM
dozanti's Avatar
Member
Forgot to mention in the middle of all of this i replaced my battery too.
Old Feb 25, 2009 | 08:53 AM
johndemon's Avatar
Thanks for the reply.
Any places online you can recommend to find a Cat Converter?
Old Feb 25, 2009 | 01:54 PM
dozanti's Avatar
Member
Jcwhitney.com
heretic
Jul 10, 2009 04:46 PM
delaveishi
Jul 5, 2009 10:27 PM
newtome
Jun 4, 2009 08:44 PM
EpiDeMiCc
Apr 17, 2009 03:50 PM
redskins2175
Jan 4, 2009 06:18 PM
