Tyre pressure loss indicator synchronisation
I have a 2014 Golf GTI Cabriolet and the low pressure warning light has just come on.
Tyre pressures all fine.
Looks easy to reset/resynchronise in the handbook.
Only one problem, no switch in the glove box.
No switch on the central console.
No reset available via the computerised MFD as it jumps from Winter tyres to Service.
Any ideas???
Any ideas???
You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check system out.
Post moved to correct section as OP can't read sub forum titles.
