Tyre pressure loss indicator synchronisation
I have a 2014 Golf GTI Cabriolet and the low pressure warning light has just come on.
Tyre pressures all fine. Looks easy to reset/resynchronise in the handbook. Only one problem, no switch in the glove box. No switch on the central console. No reset available via the computerised MFD as it jumps from Winter tyres to Service. Any ideas??? |
Default Welcome to Volkswagen Forum - Rules & Recommendations You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check system out. Post moved to correct section as OP can't read sub forum titles. ;) |
Thanks,
Currently no error codes with hand scanner, I will have a look at the new location. I had the PD150 for 12 years, great motor:-) |
Originally Posted by Bandit1200Ken
(Post 64903)
Thanks,
Currently no error codes with hand scanner, |
Worst case, 4 new tyres in 2 months time, pre-Winter (after 25,000 good GTi miles ( in 4 years) the tyre supplier will fix it...….. or I will buy them elsewhere
