obd1 or obd2
hey guys im new to vws and i need help. i need to figure out if my car is obd1 and obd2 and what that means. whenever i look to buy aftermarket things for it that question always comes up. thanks guys.
RE: obd1 or obd2
the obd outlet is where you plug a scan tool to access your On Board Diagnostics... the obd1 or obd2 may just be a different plug? i dunno, its usually located under the steering wheel somewhere maybe that would say obd1 or 2
RE: obd1 or obd2
Okay so i found my plug it is purple doesnt say if it is obd1 or obd2. I want to know because everytime i look for an intake it asks for that and if it is has the factory air pump.
RE: obd1 or obd2
every car sold in the us after I THINK 1998 is obd2 by law you will have to look up the exact date but i think that should help. if it was before that date( what ever it is ) just ask you dealer, thay will know.
EDIT: if you dont live in the us (i forgetmany people dont) im not much help as i can barly keep up with amarican laws. but agen your dealer should be able to help |
RE: obd1 or obd2
1996 obd2
in fact any vw after 1994 is most likely to have a obd2 plug above cig lighter next to ash tray or under dash on newer ones smaller 2 pin plugs for earlyer systems white and black sometimes a tan one too found under shifter boot |
Originally Posted by Jrailer
(Post 14311)
1996 obd2
There are plenty of cheap EODB II scanners on the market, you need VAG-COM\VCDS.
DLC Socket Locations |
| All times are GMT -5. The time now is 01:42 AM. |
