Engine running bad - Injector problem Please Read
Old Sep 18, 2010 | 12:36 PM
bacchus21's Avatar
Unhappy Engine running bad - Injector problem Please Read
Hi Everyone.
I have a 2001 GT TDI 115 Golf Mk(4 i think)
All off a sudden the engine started running like poo. It shakes and vibrates at idle and 1st gear.
Mechanic had a look and said it's Cylinder 3 Injector.
Trouble is I have been quotes £350 to have this fixed.
Question is
1. Is there a powerful additive I can add to the fuel to unblock the injector
2. Any other ideas that don't cost £350
Thanks
Old Sep 24, 2010 | 04:09 AM
twilight's Avatar
About fuel right now the best diesel in the US is shell or BP both has cetane ratings 40-44 average for the truck cetane has equal mpg.So because of bad fuel your engine must not be executing properly.
Old Oct 22, 2010 | 01:17 AM
Dwrench07's Avatar
if you knew the actuation pressure you could pull the injector and to a pop test to see where the pressure is when its injecting. or swap injectors ie 2 and 3 and see if #2 is now bad then you just found out your injector is bad. then replace all the injectors. but if its a single injector fuel and an additive wont fix it
wagmar
May 1, 2011 10:44 AM
JurassicWarrior
May 27, 2008 10:51 PM
tincherb
Apr 19, 2007 12:29 AM
darekponiat
Dec 19, 2006 08:31 AM
Trader4Less
Feb 18, 2005 05:31 PM
