drop in boost
Old Dec 11, 2006 | 12:23 PM
vwsleeper's Avatar
Default drop in boost
is it normal during driving after you switch gears for the boost pressure to drop. example, shifted gears, boost at 6psi then as more rpm, boost goes down to 3-4psi. just wondering if that was normal. Oh by the way guys installed my forge DV, and boy can i tell a difference in throttle response. And could someone explain in plain english (simple terms) actually how the would tune their DV.
Thanks
Old Dec 13, 2006 | 04:02 AM
TechOhSeven's Avatar
Default RE: drop in boost
That depends how much RPM. At a certain pressure your wastegate opens up and your boost will drop because the wastegate has created a "leak". If you just shifted gears and as you are just getting into the gear the boost drops and then goes up, yes thats perfectly normal. Your diverter injects the excess pressure when you shift gears back into the turbo, which is the only reason you are holding 4psi after an upshift.
Could you be more specific on your 2nd question?
Old Dec 14, 2006 | 02:50 AM
vwsleeper's Avatar
with the forge dv, i bought the tuning kit that forge sell (separately of course) there are 2 different colored springs and small circle disc. i kinda of get the idea of tuning but some simple explanation can assist me. inside the dv is a spring that is supposedly to match the stock dv, but is uprated, more stronger, etc. who knows. any info will help
daryl
Sep 7, 2012 05:07 PM
low04gix6
Feb 15, 2007 02:17 AM
discophus
Jan 25, 2007 04:17 PM
JettaMike
Jan 11, 2007 08:14 PM
torres
Jul 4, 2006 12:25 PM
