charging system nightmare please help!
Old Feb 20, 2010 | 07:33 AM
commongroundlm's Avatar
Default charging system nightmare please help!
so a week or two ago my mechanic replaced some struts on my car right before this i noticed that one of the pulleys on the drive belt was making a horrible sound. I asked my mechanic he said it "wasnt a big deal" knowing minimal about cars but also enough that i didnt trust his judgement i told him to drive it first. Upon first drive after struts installed (dont know if related) the car needed a jump, starter sounds fine when charged just a clicking indicating not enough amps. So sure enough i thought battery or alternator took the battery off got it tested it was original, replaced it and bought a alternator. All seemed well except when he replaced alternator female electrical clip was damaged, my mechanic assured me the heat wrap and zip ties he used to secure the clip were sufficient but now im stranded again because of charge. Before car stopped lights began to come on in dash, and radio flickered, lights dimmed and i knew what was coming so i pulled over and tried to fire it up to no avail. Suspecting the alternator clip i also wonder if the voltage regulator is located inside of this peticular alternator (bosch 120 amp). Battery is literally brand new and bigger then original but recommended by shop. I know that maybe a light or accesory is triggering over use but i figure that would overstimulate the system instanteously. Help me im stuck and pissed at my mechanic!
thanks,
dan
Old Mar 19, 2010 | 01:03 PM
This kind of problem is hard to diagnose by texting. You really need a clampmeter and a voltmeter. First thing to do is make sure the connections on the alternator are sound any bad connection will cause a resistance that will restrict the flow. So you bought a second hand alternator? So you don't know if thats working as it should do.
Once you get the engine running put your headlamps on and increase the revs the lights should go brighter if the battery is recieving the current. Does the gen light glow?
commongroundlm
Feb 20, 2010 07:35 AM
armada41
Jan 20, 2009 06:32 PM
cj76
Aug 24, 2008 09:54 PM
cmac1
Apr 12, 2008 07:06 PM
armada41
May 3, 2007 10:59 PM
