Boost
Old Nov 18, 2006 | 01:55 PM
silVR6's Avatar
Default Boost
How much boost can a 1.8T handle on stock internals? I wanna go about 16PSI but im not sure if its safe.
Old Nov 23, 2006 | 05:45 AM
TechOhSeven's Avatar
Default RE: Boost
It can probably handle 15 tops safely, however you will not make any power doing so. I have dyno'd a 1.8t until it blew up, we took the tubo up to 30psi before it sploded, power actually started going down. The reason you ask? Simply put, heat. The more PSI the more heat, after you have enough heat in that turbo it loses power, and eventually you will damage the compressor or blow the whole turbo. If you are seriously considering turning up your turbo do some research, get a bigger intercooler for starters.
Randompassatguy
Sep 27, 2006 04:25 PM
freekie_deaky
Dec 30, 2005 06:18 PM
racemegti
Nov 1, 2005 03:27 PM
1lowgli
Sep 28, 2005 04:15 AM
1lowgli
Sep 23, 2005 06:54 PM
