2010 TDi Problem After Timing Belt Change
I have a 2010 Jetta TDi 2.0L that I replaced the timing belt in. I changed the timing belt and everything went okay but now the car starts and then shuts off after about 1 second. I checked the 4 hoses going to and from the fuel filter and it all seems to be functioning properly. Any advice would be helpful, thanks.
