VW Golf 4 1,6 AKL engine issue. no Engine performance
Old Jul 23, 2021 | 03:25 PM
morphxp's Avatar
Question VW Golf 4 1,6 AKL engine issue. no Engine performance
Hey all,
I buy 1999 VW Golf 4 1,6 74 kw Petrol with issue. Its hard to start engine. If engine starts, it shaking and working innormal. Crankshaft and camshaft sensors replaced. Spark plugs and spark plugs wire preplaced.
Diagnostic show ( Autocom) 01177, 01314, and +30 terminal issue, but all was deleted after first my scan.
Most interesting was that when I want see live parameters, they random change every 5-10 seconds.
Check video :
Anyone have idea how to found solution for this issue ?
Old Jul 23, 2021 | 03:30 PM
morphxp's Avatar
Also engine is laggy. He slow increase and decrase RPM. Sometimes increase and keep that rpm for some minutes (maximum 2 mins even)
I tried order ECU from ebay, but this idea dont work. Recieved ECU was with immo, and I cant test it normally. Immo cluster light was blinking and I cant start even. But even with buyed ECU engine parameters were unstable.
When I put back OLD ECU, noething changes.
When car is off, and ignition is on, diagnostics anywhay show jumping parameters...
I tried disconnect engine wiring loom from ECU, make diagnostics, even with all sensors disconnected, it show jumping parameters.
I tried disconnect Crankshaft sensor while engine was idling. But noething changes - engine was indling, shaking, RPM and other params was jumping.
Zdeno
Nov 24, 2019 10:04 AM
fergusharris37
May 9, 2015 08:39 AM
Ludvig Green Andersen
Dec 26, 2012 12:53 PM
