-   -   Seized rear door lock Mark II Golf ... Help !! (https://volkswagenforum.com/forum/volkswagen-golf-22/seized-rear-door-lock-mark-ii-golf-help-887/)
Strider52 Jun 12, 2006 09:45 AM
I have a real problem here .........my trusty old H reg Golf is due MOT soon - and I have just found - as I don't normally use it - that the rear o/s passenger door lock is seized in the locked position with the door closed.
I 've tried taking the internal door panel off and manipulating the lock levers by manual means but no joy... so it looks like it's fully siezed even after a good soaking with WD40. I've taken the door rubbers off to get a view of the lock and pin and I can see it but not do any thing much else. It' so frustrating - I don't want to damage the door as the body work is good for the age - but to replace and respray - it wouldn't be cost effective ontop of the other stuff I know needs doing for the MOT. Any bright ideas ?
Jsd Jun 12, 2006 08:20 PM
RE: Seized rear door lock Mark II Golf ... Help !!
You can try using a product called 'Breakaway', much stronger than WD40. If that doesn't work, you might have to replace the whole lock assembly. I don't know what else to suggest, hopefully others will have some ideas that are more beneficial to your problem. Personally, the rear door handle is broken on my VW, I could care less to replace it lol...it happens, locks, handles, in the end, usually end up being replaced, unless you come across a trick to fix it. As well, sometimes, using excessive force can unseize or fix it :-) Just pull on it till it goes...(last resort)
-Jeff
Strider52 Jun 13, 2006 09:25 AM
Thanks Jeff
I'll try the Breakaway - but I've tried the brute force method - and I'm sure I need the door to open and close safely for the MOT don't I ? So I can't just leave it. A thought occurred to me - do you think I could cold chisel the lock catch off ?
Cheers
Jsd Jun 13, 2006 12:54 PM
Yeah, the door must open period and close properly. You could try that, I would at any point now to make it pass. Just get that door to open and close, worry about it locking later.
-Jeff
smorgas Jun 26, 2006 11:57 AM
I've just had my mk2 mot'd and the rear door is completely siezed shut - it passed - it's only the front doors that need to open - google the mot test to check.
Hope that helps.
Matt
Strider52 Jun 28, 2006 10:45 AM
Cheers Matt - I guess I should have checked the MOT site
But as it happens by judicious use of a narrow cold chisel I got the lock catch open ( locking pin intact), forked out a tenner for a lock from scrap, fitted it yesterday and its fine again.
Thanks for your comments
Paul
