MkV coolant loss
Old Jan 15, 2009 | 02:41 PM
robdub's Avatar
Default MkV coolant loss
Hi folks. Does anyone else own a MkV Golf 2.0GT FSI (2005) that loses coolant? My car’s just four years old and has covered 34k, a couple of months back it started to lose coolant at the rate of about a litre for every 250/300 miles. Every car I’ve owned in the past has only needed a slight top up about every 5000miles. At first I couldn’t see any drips under the car engine bay area so was finding it difficult to trace. There's no milky froth in the engine oil so hopefully the head gasket's fine. I took it to my local V.W. dealer who diagnosed a split top hose (although I didn’t see this when I visually inspected it) so I told them to go ahead and repair it. That didn’t fix it and I also started to see a leak on the driveway, under the engine area following the ‘repair’. I took it back and they then diagnosed a leaking water pump (on a car with 34k on the clock??) After having to negotiate their ridiculous price down I went ahead with the work. The car is still losing water and I’m rapidly losing (or probably have lost) faith in the dealers ability to sort the problem. I know previous models of Golf had similar issues (for which I don’t know the cure unfortunately) but thought they might have ironed them out by now. Anyone got any ideas before I let them try to fix it for a third time.
Old Jan 15, 2009 | 06:19 PM
bagel's Avatar
Default RE: MkV coolant loss
my hose coming from the heater core on the firewall was leaking and I couldn't even see it cause the rack & pinion is there so it drips on that and not the ground.
Old Jan 17, 2009 | 06:02 AM
robdub's Avatar
That sounds as if it might be the problem. Sometimes when i first start the car in the morning i can hear a bit of a gurggling sound coming from within the heater area, perhaps air is leaking into the heater matrix/core then as a result of a water leak around that area.
Thanks for that bagel, looks like you might have found me the answer, or at least pointed me in the right direction.
Alex5357aa
Nov 1, 2012 12:38 PM
vwbob
Jul 29, 2012 06:14 PM
robdub
Jan 31, 2009 10:22 AM
WoDan23
Apr 2, 2007 01:47 AM
