Location of ABS module
Greetings!
I bought a '95 VW Golf Mk3 last fall. It's a great piece, but unfortunately the ABS doesn't seem to work. The ABS light doesn't turn on in the dashboard, but I always skid and the breaks lock when I hit the breaks hard on slippery or wet surfaces. I've been trying to locate the ABS module to get some serial numbers for info, but had no luck. I don't know what it looks like or where exactly look for it. Maybe some of you veteran Golf owners can help me with some guidance? Thank you very much! |
It should be around your master cylinder with a bunch of brake lines coming out of it.
