Help with engine conversion please
Hi, i have 1.4 golf mk3, which i can't sell. I am planning to put a mk3 vr6 engine into it (already uprated the brakes and suspension). Would i need the clutch and gearbox changing as well? Is there anything else i am missing?
Thanks for your time
you should replace the gearbox & check that if any part in the engine require maintenance or replacement. if it required then do it.
used autos
used autos
Dicey
Oct 10, 2007 07:46 AM
