gas mileage?
Old Sep 15, 2010 | 04:39 PM
Mikhail102's Avatar
Exclamation gas mileage?
im getting bad gas mileage. oil is new, i just recently put in a k and N air filter, the spark plugs are almost new.
what is wrong with my mochine???
Old Sep 15, 2010 | 06:54 PM
elrocco88's Avatar
what kind of car is it?? have u check the tires for proper inflation??
Old Sep 18, 2010 | 11:33 AM
Mikhail102's Avatar
Default Info
Its is a 1999 old bodystyle Golf, 2.0 litre engine
i check my tires every 2 weeks to ensure they are properly inflated.
Old Sep 18, 2010 | 12:32 PM
elrocco88's Avatar
You should throw in some of that injector cleaner stuff in ur gas tank. I use the chevron bottles. Have u replaced the fuel filter?
Old Sep 19, 2010 | 10:09 AM
Mikhail102's Avatar
Default fuel filter?
i tried the fuel injector cleaners, fuel system treatment, gas mileage improvers, but i have not tried the filter. i will give that a shot n see where it takes me.
Old Sep 21, 2010 | 04:49 AM
twilight's Avatar
It will definetely help you, i did so because me also had the same issue then i replaced the fuel filter now it is smoothly executing and no more brain shots regarding the mileage.
Old Sep 21, 2010 | 01:19 PM
  #7
elrocco88's Avatar
After a while that fuel filter becomes clogged. So, there isn't much fuel going through...
Schmitty
Apr 28, 2008 08:19 PM
lavelle_04
Apr 8, 2008 03:36 PM
hunwicks01
Sep 27, 2007 05:01 PM
Tater
Mar 2, 2007 12:09 AM
CB 71
Jun 18, 2006 09:37 PM
