fuel leak
Old Sep 15, 2008 | 07:43 PM
sparhawk's Avatar
Default fuel leak
there is a lot of back story on this vehicle, but to cut to the point on my 93 mkIII golf with a 1.9 diesel, there seems to be a fuel leak coming from around the injection pump area, and it runs down the face of the block and puddles on the ground. i though it was the bolts holding the distrubition head were loose, checked those and they were about a 1/4 turn loose. rechecked it and it seemed to stop, but after approx 5 min of idling, fuel puddles on the floor.
if any one has any tips or ideas i would like to hear what you think, or if you need the hole story, i will type it up if you think it will help.
Old Sep 15, 2008 | 10:28 PM
Jrailer's Avatar
Default RE: fuel leak
how are your loop lines (small hoses) between the injectors
Old Sep 16, 2008 | 06:27 PM
sparhawk's Avatar
they were replaced in the process, but i will have to double check to make shure, at the same time i will also check the hard lines at the injectors.
Old Sep 16, 2008 | 07:51 PM
sparhawk's Avatar
just checked and all the loops are on and are tight, same for all the injection lines
SirRay
Jul 19, 2010 10:21 AM
geopat89
May 21, 2010 10:21 AM
surveyguyOR
Jan 18, 2009 09:12 PM
monkeyfist
Jun 7, 2006 03:44 PM
