ECU problem?
I went to start my R and started right up no problems. Let it run for a little bit because it was a little chilly out, then it just shut off on me. I tryied to start it back up and would not start up it turns over but does not start. So today i hooked up my computer scanner to my R and says it has a communication error with my ECU and it has read my ECU fine in the past. So now I am stumpped as of what could be wrong? Can there be a problem with my ECU can they just die?
oh and i checked all fuses they are good and all lights in dash turn on as if it was fine. Thanks |
I think you need ECU programming, VAG tools can help you
Originally Posted by Gewing4
(Post 56649)
oh and i checked all fuses they are good and all lights in dash turn on as if it was fine. Thanks Sounds like your ECU shot. |
| All times are GMT -5. The time now is 06:41 AM. |
