E-Brake indicator light won't turn off???
Just wondering if someone has had this problem it started a couple of days ago. I don't normally use my e-brake. It started by just flashing on/off but now it is contantly on.
Anybody have any ideas?????
Thanks
Thanks
RE: E-Brake indicator light won't turn off???
try chekin the brake fluid it might be lowmight work aint sure but its worth cheking get bak 2 me if it is or it aint if it aint i can then slap my self for making a silly suggestion.take a look thow
just an idea.... raise and lower the handle abit to see if its just seated a hair out of reach of the switch. if its a standard your daytime running lights might not be on. if nothing else helps pull the center console and check if the switch is good. keep us posted
iceman_ch
11-26-2008 11:36 PM
