Cooling fans not coming on?
Hey guys im new here. Got a question about my 2002 Golf (2.0 gas). My cooling fans are not coming on at all causing the car to overheat when i let it sit and run for 10 or more minutes. My A/C is also not working. I can hear it trying to do something when i push the A/C button but no cold air. I replaced the low pressure switch and checked the freon and they are fine. Any ideas? Just wondering if these 2 problems are linked somehow? The A/C randomly works sometimes, but the last few times i tried it it didnt.
Anyone?
i think the fans should come on when you turn on the AC. if they dont then check to see if you have voltage to fans when hot. probably no current there so i would check for blown fuses or bad fan relay
ok i got it pulled apart today. there are 3 wires going to the fan. A brown wire, a white/red wire, and a black/red wire. which is the ground wire, and what do the other 2 wires do? I am going to try to hotwire the fan and make sure it works but im not sure what the wires are, and i dont want to mess anything up any worse than what it already is. Thanks for the help guys. |
i got it fixed. it was the coolant fan relay under the dash. 18 bucks from NAPA.
Help with fans
Hi there...
I got a VW Golf 4 from 2000, 2.0 gas. My problem is that the fans won't stop running. It's a big problem because it drains the battery. Now i pull off the battery so the battery is not going flat, and when i put it back on, the fans starts right away. Have you ever heard about this before? |
