94 GL Running Terrible
This is my first VW and I don't know too much about them. Here is my problem, I haven't started my car in over a week. The other day I went out to pick up some things and when I went to start it, it hicuped a few times ran really rough and quit. I started it again this time it continued running but the idle was rough, I started off in first and it was running fine, put it in second and it was hitching something terrible. The car was running for approx 20mins and not getting any better in second gear, so I ran the **** outta it 6K in second and so on. After that it ran great, I went to the store turned it off started it again and went home again with no problems. Well today I went out to start it and it will turn and turn and turn, and nothing not even any signs of wanting to start. Any ideas?
very true, I thought I had a misfire cause my car wasn't running very soon, I changed all kinds of things. Even ran engine codes which said misfire, turns out the cat was red hot and glowing, so it's plugged. Who knew simple things fix huge problems?
I wish I had simple problems...both front wheel bearings, both tie rod ends and both ball-joints hahahahahaha
My baby is in for some serious TLC. Oh, a while ago I couldn't diagnose this clunking sound I was getting over bumps and what not and it was driving me nuts. Since the wheel bearings are being done, we discovered the ball joint was at the end of its life...which clunked since it had so much play. So happy I found that stupid noise.
-Jeff
-Jeff
Yup...im kinda ticked off though. I went to get a wheel alignment done a good while ago, before the wheel bearings started to go and I told the guy to check my ball joints for any play, he says he did but I know he didn't check them properly. Resulted in an inproper wheel alignment and now I have to go back and get another one done, but this time it'll align properly...not going back to that guy though!. It drives straight but lets see how long I can tolerate my steering wheel being ridiculously off centre lol.
-Jeff
-Jeff
Sorry about the delayed response but it ended up being the rotor button...the metal piece that comes in contact with the distributer cap was half missing. Now I have a new problem
the car is smoking bad oil smell, what is gone now? Rings? Valves? Something else?
