87 golf 1.8 no power warms up runs good
Old May 31, 2011 | 01:49 AM
piyush123's Avatar
Default 87 golf 1.8 no power warms up runs good
I have a 1987 Golf 1.8 Car had been sitting inside for 4 years and trying to get it running good.I have drained the tank,Installed a new outer fuel pump,Pump in tank is fine,replaced fuel filter,rebuilt fuel distributer,fuel pump relay and new plugs.When you first start the car it runs very poorly and you can put the pedal to the floor and the engine just sounds doggy no power.After the vehicle warms up about 5 minutes it seems to run real good.Shut the vehicle off and restart it after 3-4 minutes its doggy again and no power again until it warms up again about 5 minutes.We found that a mouse had stored corn in both of the mufflers so we cut those off and we will install new ones.That didnt make a difference how it is running.Any ideas on what might be the problem and if you have ran into this before?Thanks for your time!
Oct 23, 2010 05:02 AM
hellboy490
Aug 11, 2009 04:15 PM
jasmatshi
Feb 24, 2008 04:08 PM
jim
Feb 5, 2007 01:31 AM
sheil
Oct 13, 2006 04:02 AM
