2000 Golf Rally Auto not changing Gears Properly
Old Apr 11, 2011 | 07:04 AM
piyush123's Avatar
Default 2000 Golf Rally Auto not changing Gears Properly
Hi guys,
I've just got myself a 2000 1.6L Golf Rally (Auto) and within a week the driver side window regulator died on me. Cost me A$420(A$258 for the part) to fix at Woodcock Auto Electricians in Eastwood, Sydney. But thats all done and forgotten - I read here that its a pretty common problem in VWs.
I have a new problem now. It seems that there is something wrong with the transmission as the gear changing is not smooth at all and this just happened yesterday - before that it was fine. The gear now drags to about 3000 RPM when I hit about 50-60 KMH and it doesn't switch to a higher gear no matter what I did. It only does so when I drag it to about 4000 RPM and about 75 KMH then it shifts up with a noticeable jerk.
It used to be able to cruise at about 2500 RPM and changes gears smoothly at between 2000 and 2500 RPMs. I've read in my manual that there are two different driving programs in the automatic gearbox. One is ECONOMIC where it switches up faster to save fuel and SPORTY which drags the gear a bit to get more power. It also says that this is determined automatically by reading how I drive and depress the accelarator. But I am sure I have hardly dragged my gears so I don't know why it seems to be always in SPORTY mode. It does switch back to the smoother ECONOMIC mode after about 15-20 minutes of driving though.
Anyone has any ideas why this is so? Is there something wrong with the transmission or maybe the engine needs a tuning? I don't think its a problem with the engine temperature because it happens when the engine is hot and cold.
Thanks in advance for all your help, really appreciate it.
Cheers
Old Apr 25, 2011 | 02:50 AM
Jinpp.Liang's Avatar
Member
M4V is a kind of format used for video podcasts, based on a codec used by the QuickTime. This codec is a part of the MPEG-4, a global multimedia standard and this standard was introduced to provide optimized video podcasts for the video iPod.
Professional m4v to dvd mac software can help you to convert m4v to dvd mac.
Step1. Add M4V video
Click the "+" button to add the M4V video files you want to burn, you also can drag the M4V video directly to the program. The added M4V videos will be shown in thumbnails in the right pane.
Step2. Edit M4V Video
You can Crop M4V Video, Trim M4V Video with the editing functions, you also can choose to customize DVD Menu and "Preview" the M4V video, editing function for mac is just optional. You can skip to the next step – click the "Burn" button to burn m4v to dvd on mac directly.
Step3. Start Burning M4V Video to DVD
After all is set, please click Burn button to burn m4v to dvd on mac.
Note: It will take you about 30 minutes to finish
mac m4v to dvd conversion . Then, you can enjoy and share the DVD which was burned from M4V Video on your DVD player!
mariposa
Mar 8, 2011 12:28 PM
dirtykurte
Aug 4, 2010 10:18 PM
jquinonez
Feb 11, 2009 07:13 PM
buggaboolova01
Apr 23, 2008 08:58 AM
markkk1965
Sep 28, 2007 11:22 AM
