1996 VW Golf 1.8L reservoir/coolant problem
Hi guys,
I'm suffering from a problem with my coolant light that doesn't stop flashing on my dashboard, despite checking the level numerous times and seeing it's ok. Could it be possible I have a faulty sensor? Is that thing common in Golf's that age? Thanks :) PS - Temp never goes above 100c |
Sometimes seeing is not believing.
Did you actually add coolant . Add coolant when the engine is cold and make sure the cap is on tight, and check that your cooling fan comes on before overheating. |
Sounds like a bad coolant sensor..Bring it in and have the sensor checked or replaced..that is what happened to my volvo parts before..
as well as the white plug on the back of the instrument cluster mine keeps going off as well but its from loose wires
