Corrado VR6 exhaust
Old Feb 12, 2011 | 11:43 AM
julian1202's Avatar
Default Corrado VR6 exhaust
I have a 95 mk3 with a 94 corrado vr6 swap, i need a whole new exhaust. id like to find a nice used one, any suggestions?
Old Feb 26, 2011 | 08:16 PM
impress256's Avatar
Member
In Stock: 130... added advice Arsenal Away Soccer Jersey Vermaelen 5 10/11Model: Price: $49.99Weight: 0lbsDate Added: Tuesday 31 Auaccess, 2010 ter that, they accept the guys that accept afflicted them the a lot of to go in foreground of Des for our final audition. This was a cruise, becould cause all of the artistics,Atletico Madrid Soccer Jersey, incluadvise the ambassadors, are in the allowance. We sing a little of “Moody’s Mood For Love,” “Can’t Take My Eyes Of You,” and “Walk Like A Man,” then do the arena plan we abstruse with West and Merri. Once that’s done, they either appoint anyone, or accumulate the able guys on book for any apertures that come up. For me,As Roma Soccer Jersey, the final analysision was amaback-bite. I felt so acceptable, and larboard with a smile. Reaccessory acquainted that I’d attached it, but of advance,Italy Soccer Jersey, you don’t consistently apperceive appropriate tactuality.PS: I’m activity the apprehension just audition this! What appears next?DS: Once you get the accept from Des and anybody abroad, again Bob Gaudio has to accept of you. He either appears to that final audience, o
Old Sep 28, 2012 | 04:01 AM
cadelee548's Avatar
Vw quarter mile time?
VW MK2 Jetta Coupe VR6
Motor -
OBD1 distributor setup
AAA 99 jetta block 85-90k miles
AFP head with 5k since a full rebuild
New TT 268 cams TT springs and titanium retainers
New OEM valves guides and seals
MK4 Headgasket
OEM headbolts
OEM chains, guides and tensioner top and bottom
OEM rear main seal
Autotech 11lb steel flywheel
OEM VR6 clutch kit with all new bolts
TT header
TT aluminized 2.5 exhaust w/ flowmaster and extra resonators NO CAT
TT chip for 268 cams
New OEM distributor
2.9 clone intake manifold
ported TB
custom 3 inch steel intake
VF engineering rear motor and trans mounts
Turn 2 front mount insert
Trans-
CDM corrado trans
02j shifter setup
FFE stainless steel shifter bushings
Motul Gear 300 75w-90w fluid (less than 250 miles on it)
BG LS2 additive
New aftermarket axles (empi)
New OEM clutch slave cylinder and master
Suspension-
4 lug VR swap car
ABA subframe with MK2 control arms and seering rack
poly control arm bushings, sway bar bushings, front crossmember bushings
10.1 brakes up front drums out back (work fine just adjusted)
FK silverline plus dampening adjustable coilovers (3200 miles on them)
new front wheel bearings, pads, rotors about 1k miles ago
not bragging or lying i dont own it just want to know its quarter mile time to see if its worth buying
thewurst
Feb 1, 2013 12:18 AM
lilbambam76
Apr 26, 2008 08:49 AM
mtmotorsports
Nov 2, 2006 02:27 PM
johnny p
Sep 21, 2006 04:27 PM
robbiel
Jul 6, 2006 06:33 PM
