98 cabrio headlamp replacement
Is there any size or mounting difference in single beam headlamps and dual beam headlamps on the 98 cabrio convertable? All the aftermarket replacements headlamp assemblies specify they only replace stock single beam assemblies. Just wanted to know if it was due to the size of the assemblies or due to the wiring and if it is due to the wiring if that can be corrected easily. My 98 cabrio if factory with dual beam headlamps so finding a replacement set has been impossible.
I can't tell you of hand, Google this?
