Question about Speedo not working for a 1998 VW Cabrio. Speed Sensor?
Old Jun 23, 2010 | 06:21 PM
remission's Avatar
Default Question about Speedo not working for a 1998 VW Cabrio. Speed Sensor?
My speedo stopped working and the guy at my dads shop said I should buy a new speed sensor and see if that fixes it.
Just asking if anyone has had a issue with their speedo not working and if this fixed it, or if theres something else I can try? I dont want to spend $50 on a part and then have that not fix it.
And also, how to install it? I think its behind the cluster right?
Thanks.
Old Jul 5, 2010 | 03:02 AM
elrocco88's Avatar
is yours an auto. or manual?? if you have an auto. it should on top of the transmission.
I also have a 98, but is a Jetta with a 2.0L.
Old Jul 5, 2010 | 02:18 PM
remission's Avatar
I fixed it. It was the speed sensor that was broken Easy fix.
Old Jul 5, 2010 | 10:27 PM
elrocco88's Avatar
Right on!!
Old Jul 14, 2014 | 07:16 PM
Jimmy Climer's Avatar
mine is a 1999 cabrio manual tran and my tach and speedometer went out when i went through soome water any ideas on mine
Old Jul 15, 2014 | 06:30 AM
Speed sensors are on the gearbox not on the instrument clusters.
This applies to all of you guys.
Old Jul 27, 2014 | 10:50 PM
  #7
BravoVW's Avatar
Everyones response is great! Thanks I had the same questions!
Frankie Mason
Jul 2, 2013 10:34 PM
HipHipJorge_20
Nov 7, 2011 12:32 PM
irishlassie71
Sep 10, 2011 09:38 PM
Mar 22, 2011 03:00 AM
mricha
Nov 2, 2010 12:27 PM
