Coolant Leak
Old Sep 6, 2010 | 07:48 PM
doug1asadams's Avatar
Default Coolant Leak
Have a 95 VW Cabrio that is dripping coolant below the power steering pump. Replaced the water pump due to bearing failure about 6 months ago and everything went back fine, no leak at that time. Small leak has now developed but can not locate the source. Removed pump and used tube gasket on all connections but still get the same leak. Could it be leaking from someplace else? No water in the oil and car runs fine so don't think it is head gasket. Nothing visible except steady drip under car. Is there another way to test with the car partially disassembled? What about hooking up a garden hose to pressurize system?
Old Sep 30, 2010 | 02:33 AM
elrocco88's Avatar
yeah, try pressurizing it with a garden hose. Is that the 2.0L?
cunok
Feb 22, 2012 11:06 AM
AmberH
Dec 21, 2009 12:21 PM
hood
Oct 11, 2009 01:58 PM
MB77MONZA
Nov 7, 2008 09:23 PM
user 69780823
Apr 12, 2007 09:48 PM
