Convertible Problems
Old Apr 15, 2006 | 03:49 PM
radcat's Avatar
Default Convertible Problems
[font="Times New Roman"]Is there a way to raise the convertible manually? I just purchased a 1998 Cabrio and the top will not close. Thankfully we have a garage, it has been raining[:@]. Thanks for the help!
Old Apr 15, 2006 | 08:29 PM
Maggadog's Avatar
Default RE: Convertible Problems
I think there is a way to do this. I have an '06, and the owner's manual gives detailed directions on how to do this. Check your manual, or try and get a dealer to talk you through the process.
Good luck.
Old Apr 16, 2006 | 12:03 AM
radcat's Avatar
Thanks. Thats also my problem. I purchased the car one week ago. The owners manual is for a Golf/GTI with nothing on convertibles.
Old Aug 1, 2006 | 10:58 PM
bsco's Avatar
Hi radcat
I have a98 cabrio. The procedure to raise the roof manually is;
There is a valve in the trunk on the left fender behind a plastic circular cover, remove the cover, turn the valve counterclockwise ( this releases hyd pressurein the system)
You can now raise the roof manually, raise it slowly, same speed as the motor would take. Close the valve to repressurize the system, and your done.
Hope this helped
Sco [8D]
Oct 19, 2010 03:10 AM
eautofinder
Jan 2, 2007 02:13 PM
redbuggy
Nov 28, 2006 03:15 PM
Grannycar
Jun 7, 2006 09:03 PM
cabster
May 2, 2006 09:50 PM
