-   -   Cabrio need for Timing Belt Change? (https://volkswagenforum.com/forum/volkswagen-cabrio-34/cabrio-need-timing-belt-change-33411/)
baldy_54 Sep 10, 2011 08:21 PM
Have a friend with a 2002 VW Cabrio with 70,000 miles. Is it a "Contact Engine" that a belt break, could mess up the engine? When should the timing belt be changed, mileage? Thanks
baldy_54 Sep 17, 2011 12:02 PM
Apparently there is little or no chance of getting an answer to a question on this site. Sorry to say.
DonRW2007 Sep 28, 2011 05:44 PM
Hi - new member
Hey. I just joined this site as my daughter recently bought a 2002 Cabrio and I have some maintenance questions as well. Hope I came to the right place!
At any rate, her car has 102K miles, and the first thing I thought of was the timing belt. We had it changed this weekend, including the water pump and new coolant, for $380. This is a non interference engine, I believe, so a failure of the belt is not a complete catastrophe. Not sure what the official recommendation is, but I would say that a well maintained car should be good for 100K miles.
DRW
baldy_54 Oct 2, 2011 09:28 PM
$380 for a new belt etc. Did you buy a kit? Was the job done in a Dealership? Hope you are right about "non interference engine". Thanks for a response.
Keithuk Oct 3, 2011 09:22 AM
Well you don't say which engine it has but at appears that all engines fitted to a 2002 Cabrio
Timing belt - Renew Every 48 months regardless of miles/km.
CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve-to-piston damage in the event of a timing belt failure is MOST LIKELY to occur. A compression check of all cylinders should be performed before removing the cylinder head.
DonRW2007 Oct 3, 2011 10:02 AM
Timing belt
The engine is the 2L. We had the work done at the local Goodyear; they provided the parts and labor.
DRW
baldy_54 Oct 3, 2011 03:34 PM
Keith, from the looks of it, that "Caution" was printed somewhere, can you say if it is in the manual or whatever? Thanks
Keithuk Oct 3, 2011 06:56 PM
That caution was taken from Autodata and Autodata don't list an AL engine code for the Cabrio.
ETKA says AL - 1.6 - 48hp - 03\73-12\78 - MOD.181
