98 cabrio running hot
Old Mar 21, 2013 | 02:38 PM
mman514's Avatar
Default 98 cabrio running hot
Recently I purchased a used 98 cabrio with around 109,000 miles, that at the time was running fine until it started to run hot at about 230 as indicated by the temp gauge. So I replaced the thermostat and the coolant fan control thermal switch. After that it seemed to be fixed the car ran at around 200 to 210. A week later it started to run hot again around 230. After checking the car again I found that the cooling fan was on only when the A/C is on. After testing the coolant fan control module it was bad so I replaced it. After replacing it the car still runs at 230, and when I looked under the hood after driving it the fan shut off as soon as I got the hood up. So the fan was on at some point without the A/C being on. The next thing I'm going to replace is the water pump could there be anything else that would cause it to run hot?
Old Apr 3, 2013 | 08:40 PM
go-part's Avatar
Former Sponsor
Have you tried doing a coolant flush?
What makes a car run hot
It sounds like you may be in need of a new radiator.
Feb 28, 2011 05:14 AM
centerline
Jan 18, 2011 03:04 PM
clbjms2007
Aug 28, 2010 12:52 AM
R.K.S.
Feb 10, 2006 04:55 PM
buck
Oct 3, 2005 09:25 PM
