86 Cabriolet leaks gas
Old Mar 1, 2016 | 11:47 AM
masonwalk's Avatar
Default 86 Cabriolet leaks gas
I have almost brought this thing back to life. I was driving my 86 cabby down the road the other when I noticed a strong smell of raw gasoline in the cab of the car. I looked behind me to see a line of gas trailing behind me in the road. After some inspecting, I found that the gas is leaking from under the car where the fuel pump is right underneath the gas tank. The owner before me used the wrong fuel pump relay for a different model of cabriolet and it has had new fuel pumps and lines because of this.
My question is what do I need to replace to keep the gas in the tank and lines instead of on the road and how to I drain the gas tank and keep the gas when I go to replace the lines?
Old Mar 1, 2016 | 06:43 PM
The main job is you need to check and fix where the fuel is leaking from.
Old Mar 3, 2016 | 09:25 PM
masonwalk's Avatar
I found that the fuel is leaking from a bad o ring on the fuel pump under the back seat. I will buy a new o ring and put it on within a few days to get this thing back on the road.
GTIinNC
Mar 7, 2016 08:12 AM
evildicoball
Dec 27, 2006 08:58 PM
bkrahmer
Nov 21, 2006 11:36 PM
GTIinNC
Nov 15, 2006 04:51 PM
rhoman
Jun 28, 2006 08:54 PM
