2001 VW Cabrio Not Starting
Old Nov 15, 2015 | 05:26 PM
gphesq's Avatar
Default 2001 VW Cabrio Not Starting
Girlfriends car driving on freeway, lost acceleration and stalled. Had it towed home. Did usual checks... Fuel pump, relay, fuel to injector rail, fuel pressure regulator.. etc. all seem okay. Good spark from coil and plugs. Belts look okay. Did OBDII test and have a TPS Sensor error, which probably means the TPS needs re-programming and or check the wiring. But, the car should still start right?
Anything else I can check?
Thanks.
G.
2001 VW Cabrio - Manual Transmission. (No mods).
Old Nov 15, 2015 | 07:39 PM
Are you sure the timing belt is ok?
There are 63 error codes for Throttle Position Sensor what numbers do you have?
opfor2
Jul 28, 2014 07:05 PM
Jan 4, 2011 05:58 AM
alxjhn
Nov 5, 2007 08:38 AM
camaribug
Jun 30, 2007 05:30 PM
T boy
Apr 16, 2007 12:21 PM
