2000 Cabrio Ignition Issue
2000 Cabrio ABA 2.0 Manual Transmission.
Initially would crank, but no spark from coil.
Replaced coil, ECU & Distributor.
Engine now starts, but only fires on cyl 1-3 and weak to no spark on 2-4.
All timing marks line up and distributor is positioned correctly.
Tach operates while running.
What should I try next?
Been working on this issue for 2 months now and ready to set it on fire!
Thanks In Advance.
Thanks In Advance.
Welcome to the forum.
First job is need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing.
jldcu
Jul 6, 2008 05:38 AM
