2000 Cabrio Ignition Issue
2000 Cabrio ABA 2.0 Manual Transmission.
Initially would crank, but no spark from coil. Replaced coil, ECU & Distributor. Engine now starts, but only fires on cyl 1-3 and weak to no spark on 2-4. All timing marks line up and distributor is positioned correctly. Tach operates while running. What should I try next? Been working on this issue for 2 months now and ready to set it on fire! Thanks In Advance. |
1 Attachment(s)
Welcome to the forum. Attachment 2412
First job is need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing. https://volkswagenforum.com/forum/ne...gnature-34185/ |
