1999 vw cabrio top issue not doing anything
Old Jun 17, 2020 | 09:37 PM
Daniel Carter's Avatar
Default 1999 vw cabrio top issue not doing anything
Hey everyone I just replaced a broken hose today everything is tight and does not leak, but when I tried to bleed the system with actual power, you dont hear anything, now before this like a year or so ago it worked, I've been using it the manual way by turning the T screw so it was done right constantly, I put a multimeter into the power plug and got nothing when I hit the switch inside. Parking brake on key in position 1, windows down, etc and nothing now I heard about the fuses 16 and 22 and those are not blown, i think the relay under the seat may be bad, but I'm not sure where else to look before buying more parts. Thank you!
Old Jun 18, 2020 | 08:45 AM
There are loads of problems with Cabriolet tops not working.
Old Jun 18, 2020 | 09:10 AM
Thank you for your response, I wasnt sure just wanted to get under the right thread for the vehicle, so how do they scan the motor? It's not like checking Engine codes is it? I am sure that it shouldn't have any error codes because it worked before hand and I had it unplugged, so I was just hoping to get a simple hey test this or test that replace this or replace that haha but nothing is ever simple
Old Jun 29, 2020 | 06:46 PM
So I was trying to scan my vehicle I found a friend who with an Audi has ODBeleven, I hooked it up, but idk if it is that capable because I dont see anything for a soft top but alot of other things. If I go to a Volkswagen dealer how straight forward is it for them to test, say if the motors bad, or if relays are bad? I have a multimeter, but I have no idea how to test relays. I found wiring diagrams but they mean nothing if you dont understand them, it is very difficult.
Old Dec 30, 2020 | 01:50 PM
paityda's Avatar
windows down, etc and nothing now I heard about the fuses 16 and 22 and those are not blown, i think the relay under the seat may be bad, but I'm not sure where else to look before buying more parts. Thank you!Nox Vidmate VLC
GPA
Apr 7, 2017 10:42 PM
AGalaxy
Dec 8, 2015 10:51 AM
spotty8
Jun 30, 2011 11:39 AM
mariepap
Jun 10, 2009 01:03 PM
Satellitecentral
Sep 20, 2007 07:29 PM
