1998 Cabrio oil leak
Old Feb 13, 2022 | 10:02 AM
Pkjeld's Avatar
Default 1998 Cabrio oil leak
I just bought a 98 Cabrio and noticed it has a nice oil leak on the driver side of the motor. It looks like it may be coming from the top radiator hose where connects to the block. I wouldn’t think that’s the spot butt can’t see any thing.The valve cover gasket appears to be dry all the way around. Thanks
Old Aug 4, 2022 | 02:36 AM
Dpricenator's Avatar
I am having the same issue. Imine looks like the circular area under the oil fill cap, on the driver's side of the engine. Is that a know leak point, or is it more likely the valve cover gasket?
Old Aug 7, 2022 | 02:05 PM
Pkjeld's Avatar
Default Oil leak
my oil leak was coming thru the oil pressure switch and the coolant leak was a bad gasket on the housing just below pressure switch.
cabdad
Jun 8, 2018 07:35 AM
wheelsport
Feb 23, 2017 08:52 PM
xx7xx
Jun 3, 2011 10:58 PM
pclassic944
Feb 11, 2009 01:31 PM
Lin
Aug 17, 2008 10:39 AM
