(Turn) in the treatment of cough remedy (Adult) -
Old Aug 24, 2010 | 09:17 PM
u8xn0qc9gx's Avatar
Default (Turn) in the treatment of cough remedy (Adult) -
repeated coughing, cough up as a very long time, this may be allergic cough, chronic bronchitis, emphysema, lung disease resistance. Of course, some foreign body, tuberculosis, lung tumor. So for chest cough diagnosis can be ranked to determine treatment. Apitherapy treatment of clinical results are good in many cough. Apitherapy can also use the following cough when the therapeutic side. 1, cough Houttuynia Houttuynia of water will 30 grams of egg, 1 egg. Will be fried Houttuynia concentrated juice, boiling the concoction with red, 1 egg, 1 dose, 1, 1. Reducing heat and nourishing yin, detoxification, treatment of chest pain and cough Hyperactivity. Guangdong Provincial Hospital of Apitherapy out into the Sun 2, honey, eggs, honey cough 35 grams of water, 1 egg. Honey 300 ml boiling water, into the egg. 1 dose, morning and evening empty stomach. Have the effect of lungs and cough, to treat Dryness of dry cough, prolonged cough. 3, the amount of fried ginger cough ginger slices into the pot, fry the ginger with a small amount of oil to continue on the yellow bowl of water, cook 10 a few minutes, put sugar, once finished. More drink warm boiled water. Treatment of Hyperactivity. 4, leaves feet or cough leaves 30 to 50 grams, placed about 1,500 ml of boiling water, boiled for about 15 minutes, fishing to the leaves will be fried out of the liquid into a small tub of. Put hot pots along the legs to accept fumigation. To avoid drug gas about evaporated, can be slightly larger in the tub feet covered with a cloth. Lower legs to be able to stand when the water temperature can be directly placed in soaking basin. Once every night (to sleep at best), each 1520 minutes, 35 times the general continuous cough can be cured. 5, a dozen garlic garlic cough valve, Daocheng mashed into the cup, add crystal sugar, use boiled water, warm clothes when the tea per Day 1, cough seriously, 2 times a day. The side effects with rapid refreshment, but patients with stomach Jiyong. 6, vinegar, duck 2 duck cough, vinegar 30 ml. First break the duck and stir well, add water to pot and cook for 2 minutes, and then vinegar (aged vinegar was better) and can be cooked, eggs cooked, 2 minutes warm clothes, even clothes for several days . Applicable Persistent stubborn cough. 7, Lily Lily governance autumn dryness 150 grams of dry cough, pinch to suffer sharp, stripped flap mercerized, 510 hours immersion in cold water, wash away the yellow water, hack into the Fry cook, eat sugar are added to the morning fasting eat better. Lily Yin lungs, refreshment, and back and Hot, stop hemoptysis. 8, persimmons cough persimmons 2 (stalks), 9 grams chuanbei end (into the dried persimmons in), steamed and served time, 2 times a day . Those who apply dry cough without sputum. Persimmons 3, decoction, honey Chongfu, 2 times a day. Those who apply Cough. 9, aloe vera cough and 20 grams of egg treatment, chopped into a container, into an egg, stir well, put the pot add sesame oil fried, taken before breakfast every day, you can eat for 3 days. If the results are good, could be once a week after the consolidation effect until healed. Results are obvious. 10, shepherd's purse will be fresh ginger administration Capsella cold cough 80 g, washed and cut into sections, ginger 10 Kocse films, plus 4 bowls with the boil water for 2 bowls, plus a little seasoning salt, divided 2 times a day Decoction and, even serving on the 3rd can be effective. 11, strawberry crystal sugar 500 g fresh strawberries dry cough treatment, 300 grams of crystal sugar, drain and bake stew of every day for 3 times, each time a spoon. Continuous service 57 days, the light can be recovered. If the illness serious, can serve 23 more days. 12, Pepper Powder cough edible pepper, cool and the amount of oil, to reconcile the two drugs would be to reconcile the cream stalls at about 3 cm wide, 5 cm long of The Wind paste, the paste on both sides Feishu points (touch the high back of the neck bone, then down a few three spinous process, next to the open 1.5-inch unit). Dressing was changed every 812 hours for 5 days, usually more than three days in the second drug can be effective. 13, lotus cough Tremella Tremella 10 grams, 30 grams of fresh lotus seeds, 150 ml chicken broth, salt, MSG, cooking wine appropriate, stew served. This Fangyou Run pulmonary Yangwei, the physical power tonic for throat, itchy throat, dry cough with scanty sputum and other patients, healthy people use also health prevent disease, prolong life. 14, honey, carrot juice, dry cough rule 400 grams of white radish, peeled and chopped washed with clean gauze wrapped squeeze squeeze juice, take 60 ml every a spoonful of honey, and mix thoroughly Dayton suits, 3 times a day, with service for 35 days. 15, rock sugar, stewed pears: Peel the fresh pears, cut open the core and adding appropriate crystal sugar, into the pot and steam soft serve. 16, baked orange: the orange chopsticks hit the bottom center of a hole, plug some salt, after being placed in aluminum wrap platinum oven and bake for 15-20 minutes, remove the orange peel and peeled off after hot to eat. Or the dried orange peel into a peel, water, brewing tea, drinking, breathing, quite miraculous. 17, chuanbei stewed pear: The peel to the nuclear powder 2 fresh pears Jia Chuanbei money on the pot and steam for soft, Serve hot. 18, white radish yee: the white radish cut into 1 cm thick inherit the throne, into the dry, clean container, add honey filled, tightly closed, impregnation 3 days will be leakage of water and honey mixture into the refrigerator; each scoop out a little warm water to drink, cough very good results. If the temporary drink, no time dipping can be white radish grated, plus 1 / 3 the amount of honey and mix well, add warm water to drink. 19, candied kumquat: the kumquat wash, poke two or three holes with a toothpick, add boiling water, submerge, adding rock sugar, low heat boil rotten , serve hot. Did not finish the leave to cool, into refrigerator, each scoop of some hot food. 20, do not eat candy cookies and other sweets, those cold, dry, and easily lit food such as peanuts, melon seeds, fried things, also should be prohibited. Note: The above therapeutic side, not allow you to try each of them. You can use convenient way to check against and drawn a try.
trickdog
Aug 9, 2015 11:52 AM
Market11
Aug 22, 2011 01:54 AM
Market11
Aug 19, 2011 02:38 AM
Marle
Jun 21, 2005 11:17 PM
