Problem
Old Jan 21, 2008 | 02:21 PM
scar2hand's Avatar
Member
Default Problem
i had just changed my points in my 73 type 1 bettle. now i cant get the car started what could be my problem.
Old Jan 24, 2008 | 11:35 AM
Smokin Dog's Avatar
Default RE: Problem
The points in the ole beetle was bad about shorting out,
If you got the gap set correct, just wiggle the points around a bit and most of the time the short goes away.
Did you rotate the engine to where one of the 4 little
lobes in the distributer was touching the rubbing block on
the points and then set the gap. the gap is .018
