Painting Help
Old Oct 4, 2008 | 02:39 PM
bandgeek1's Avatar
Default Painting Help
Ok so I am going to paint my 66 Bug soon, never done it before, but i have done my homework.
One question tho, I want to paint the fenders the same as the car, is there any special kinda of paint i need to use on them?
Thanks
Old Oct 4, 2008 | 02:41 PM
bagel's Avatar
Default RE: Painting Help
What material is the fenders made out of? You shouldn't have a problem, but are you wet sanding between coats?? What type of clear coat sealer do you have??
Old Oct 4, 2008 | 03:42 PM
bandgeek1's Avatar
They are made out of rubber.
And i have not started painting yet, still doing some research. If there any tips tho, i would appreciate it.
Old Oct 4, 2008 | 04:47 PM
Jrailer's Avatar
rubber fenders?
Old Oct 5, 2008 | 01:15 PM
bagel's Avatar
Fenders aren't made out of rubber, usually a plastic or a composit material. I wet sand in between coats with 500-800 grit sandpaper. paint-wet sand...paint-wet sand..and then paint and you should be fine. You have to clear coat after you're done painting. Don't go to fast cause you'll get blotches, go to slow you get runs. Test on a separate peice of metal to see what you're paint will look like.
Old Oct 5, 2008 | 02:16 PM
Jrailer's Avatar
ya a 66 bug should have metal fenders
might have some fiberglass aftermakets but i have never seen rubber ones
copeme
Oct 16, 2011 05:35 AM
Gewing4
Oct 8, 2011 09:41 PM
bagel
Feb 3, 2009 09:02 PM
GettaJetta
Sep 27, 2008 12:34 PM
