Need Help 99 NEW Beetle!!
Old Feb 6, 2011 | 10:20 AM
piyush123's Avatar
Default Need Help 99 NEW Beetle!!
VCDS-Lite Version: Release 1.1
Wednesday, 12 January 2011, 15:50:10:44011
Control Module Part Number: 06A 906 018 JE
Component and/or Version: MOTRONIC M5.9.2 AT V01
Software Coding: 00001
Work Shop Code: WSC 01120
VCID: 6EAFE6503999
3 Faults Found:
01165 - Throttle Body Control Module (J338)
55-00 - Adaptation Not Successful
17952 - Angle Sensor 1 for Throttle Actuator (G187): Signal too Large
P1544 - 35-00 - -
16505 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 35-00 - -
What CAN i do?
Old Feb 18, 2011 | 03:26 PM
Originally Posted by piyush123
3 Faults Found:
EOBD II Error Code: 01165
Fault Location:
Throttle Body Control Module (J338): Adaptation Not Successful
Possible Cause:
Throttle Body Adaptation Conditions not met.
Throttle Body Control Module (J338) faulty.
Possible Solutions:
Check for other Throttle Body related Fault Codes.
Check Throttle Body Control Module (J338).
VAG Error Code: 17952
EOBD II Error Code: P1544
Fault Location:
Throttle motor position sensor 1 - high input
Possible Cause:
Malfunction indicator lamp (MIL) Triggered on first occurrence.
Wiring short to positive.
Throttle motor position sensor.
VAG Error Code: 16505
EOBD II Error Code: P0121
Fault Location:
Throttle position (TP) sensor/switch A/Accelerator pedal position (APP) sensor/switch A - range/performance problem (G69)
Possible Cause:
Accelerator cable adjustment.
Throttle position (TP) sensor/switch.
Accelerator pedal position (APP) sensor/switch.
As taken from my Free EOBD II Error Codes software
Santa Albert
Sep 9, 2013 01:24 PM
W8vdubgirl2010
Jan 3, 2011 02:30 AM
stonesjunkie
Jun 22, 2009 12:34 PM
Ness010
May 1, 2009 09:01 PM
pwn_zmr
Nov 2, 2008 08:35 AM
