NB Secuirty Issue after Lock Cylinder swap...
Old Aug 1, 2010 | 09:27 AM
SunfireSSR's Avatar
Default NB Security Issue after Lock Cylinder swap...
I have a 2000 Beetle. The internal spool for the ignition switch assembly (between the switch and lock cylinder) had the tab to the switch broken.
I replaced the switch and the internal spool.I replaced the lock cylinder also with one that had a keyfob (none matching to the car)since all we had was a valet key.
I tried the new lock cylinder and keyfob first but couldn't get the car to run more than (2) sec's due to the security system. So I put the old lock cylinder back in and the security system still won't let it run for more than (2) sec's.
I can usually disconnect the battery cables and touch them together for about 10-15 seconds to clear the security. I did this over and over between swaps. I also tried locking the doors with the back hatch open and shutting it. Nothing has worked.
I also pulled up instructions to program the new keyfob (about 3 different versions) and all of them failed to work.
At this point, the Beetle has the original lock cylinder and the valet key in it. What do I do ? Thanks in Advance !!!
Old Aug 1, 2010 | 05:02 PM
SunfireSSR's Avatar
Woo-Hoo !!! Short Story. Gave up on the Beetle. Went into the house to take a break from it for about an hour. Went back out to push it in the driveway 'til later. I had left the Valet key in the ignition while I was in the house. Turned the key to back the car out and noticed the Security Light wasn't on. The car started and runs !!!
Tyler St.Clair
Sep 9, 2013 09:01 PM
ktfjammer
Apr 12, 2009 07:35 PM
andyk97golf
Oct 23, 2008 07:44 PM
Doob
Nov 26, 2007 05:59 PM
aleols
May 6, 2006 04:22 PM
