low idle when warm
Old 11-10-2008 | 06:47 PM
iceman311's Avatar
Default low idle when warm
can someone give me some advice on a 2000 bug, the problem is the engine started to idle real low , close to 400 rpm. the problem only happens when the engine is warmed up. the car has been to several mechanics and still no answer. any info would be great? thanks.
Old 11-13-2008 | 06:03 AM
Dewald's Avatar
Default RE: low idle when warm
Check if you have an oraginal distruboter and check the choke.
Old 11-13-2008 | 10:49 AM
Jrailer's Avatar
ORIGINAL: Dewald
thiscar dosnt have distributor or choke
might need a remap of the throttle body
Old 11-13-2008 | 12:52 PM
dubalicious's Avatar
I think he missed the 2000 part there J. but at least im not the only one who can't spell
Old 11-13-2008 | 08:38 PM
iceman311's Avatar
thanks for all the replys. is it possible that the cruise control part of the intake maybe at fault? ive noticed that it has a vacum vavle before the cruise control, and just to try it took i off the tube. after this i let the car warm up, and it did not drop the idle. from what i have heard this vavle helps keep the idle up when shifting. if this is true i wonder if if i can bypass or fix this problem.
Old 11-14-2008 | 07:09 AM
skoobahead's Avatar
If you found a vacuum leak you have found your problem.
napleswebguy
10-03-2012 04:23 AM
millereric
03-15-2010 06:18 PM
kenv1
01-24-2010 09:13 PM
nacoya
08-25-2009 02:25 AM
LittleBill
08-28-2007 12:51 PM
Quick Reply: low idle when warm
