left side of manifold not warming up
Old 06-21-2006 | 05:45 PM
hungpowchicken's Avatar
Default left side of manifold not warming up
when i run my car, the left side of my manifold is dead cold, while the right is normal, it seems this is comonly a problem with spark plugs so i replaced all those and the wires, but that didnt solve the problem. im not sure if the problem could be with the carborator, but i converted the generator to the alternator, and had to grind down a screw a little to make it fit, yet i did this with my last car and everything worked fine after. i also replaced the distributor with a c009, which i guess has a flat spot on it because the engine needs to idle higher with it, and my engine rattles a lot when i idle, so i also wonder if it could be anything along those lines causing the problem. it is a 71 super beetle that i am working on. thanks in advance
Old 06-28-2006 | 06:43 AM
Chrisgooleyh's Avatar
Default RE: left side of manifold not warming up
Have you lost acceleration?
paulclark51@live.com
04-04-2011 05:19 PM
nicolas7
06-30-2010 07:22 AM
giddy1945
11-20-2007 06:34 PM
98Cabrio
07-20-2005 07:26 PM
