Climate Control
Old Dec 5, 2007 | 07:30 PM
ptcruiser07's Avatar
Default Climate Control
My daughter has a 1998 beetle that the blower motor switch doesn't work. Do all 3 switches come as a set or can you buy just the one you need? Also is it possible that it could be the blower motor resistor? I replaced the blower motor so I know thats not the problem.
Roger
Old Dec 7, 2007 | 08:44 PM
mausolfh's Avatar
Default RE: Climate Control
Roger,
Backprobe theconnector to the blower. If you replaced the blower we can assume it is good. Connect a voltmeter to theconnector and turn the ignition on(it doesn't have to be started). If you get varying voltage as you go through theswitch positions it is good because this is how blower speed is controlled. If there is no voltage in any position check the resistor. Disconnect the electrical connector from the blower resistor and do the same voltmeter check. This should confirm it is either the switch or the resistor. The heater/air conditioning control assembly comes out as a unit, but the switches are independent, but I don't know if they will sell just one.
westerton
Nov 22, 2008 05:36 PM
99JerseyPassat
Sep 23, 2008 11:04 AM
mattandjay
Jan 18, 2008 02:02 AM
stasiak
Jul 26, 2006 06:49 AM
patelm01
Jan 2, 2006 04:43 PM
