Bow on Drivers side door
Old Apr 15, 2018 | 07:44 PM
billriv's Avatar
Default Bow on Drivers side door
I recently learned that the part that holds the drivers side exterior door handle and lock cylinder in place is called the bow. I broke the bow after I installed a door actuator in the drivers side door and put the lock cylinder back in place. I pushed the lock cylinder into its opening next to the exterior door handle and tried to finish the install by screwing in the mounting screw through the threads of the bow, but the bow cracked. I replaced the bow, but the lock cylinder doesn't stay in place. Any ideas.
Old Apr 16, 2018 | 07:15 AM
Its isn't easy to say what that part is called there are many door lock parts, can you post a picture?
Old Apr 16, 2018 | 08:08 AM
billriv's Avatar
Default VW door Bow
Thank you for responding to my post Keithuk. Below is a link to the image of the door bow I installed in my 2001 New Beetle. I have also attached a file that is a blow up diagram of the door parts that includes the bow circled in red. Hopefully this may help someone help me fix this door lock problem.
https://goo.gl/images/PVyqnN
Old Apr 17, 2018 | 08:16 AM
ETKA calls that part number 1C0837885B - Mounting bar - £57.44 was dropped on 01/12/2007 for 1C0837885C - £62.96
Oct 29, 2010 02:43 AM
kailas
May 13, 2009 08:39 AM
Castro27
Feb 5, 2009 07:52 PM
Schmitty
Jul 31, 2007 04:30 AM
speedtrap
Jul 28, 2005 01:14 AM
