2005 aux brake vacuum pump question
Old Jan 14, 2020 | 02:48 PM
Kantanshi's Avatar
Default 2005 aux brake vacuum pump question
Working on a 2005 Beetle and the auxiliary brake vacuum boost pump appears to be malfunctioning. The numbers on the sticker are:
862664-01
1.13.051.206
I have not been able to find a replacement so far. Is there an alternate number I can look for such as a 1J0 part number? Thanks in advance.
Old Jan 15, 2020 | 09:52 AM
Old Jan 15, 2020 | 11:01 AM
Kantanshi's Avatar
That's the problem. No codes are coming up but the pump motor doesn't stop running so they have to disconnect the battery.
Old Jan 16, 2020 | 07:55 AM
No error codes scanned with what, a generic scanner?
Old Feb 24, 2021 | 01:34 AM
Resarsx's Avatar
VW dealer wanted roughly $400 to do this. This video is the best I have found on this topic, thank you sir.
snaptube vidmate
Phil Kilburn
Jan 5, 2020 03:09 PM
Gorhad
Oct 14, 2019 06:57 AM
Trtatywe28
Sep 27, 2019 10:24 AM
curtis79
Jul 23, 2019 08:39 AM
James Eaglen
Nov 2, 2016 07:38 AM
