2005 aux brake vacuum pump question
Working on a 2005 Beetle and the auxiliary brake vacuum boost pump appears to be malfunctioning. The numbers on the sticker are:
862664-01 1.13.051.206 I have not been able to find a replacement so far. Is there an alternate number I can look for such as a 1J0 part number? Thanks in advance. |
Default Welcome to Volkswagen Forum - Rules & Recommendations You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out. |
That's the problem. No codes are coming up but the pump motor doesn't stop running so they have to disconnect the battery.
Originally Posted by Kantanshi
(Post 65927)
