2000 VW Beetle Cooling Fans
Old Sep 18, 2015 | 11:14 AM
Ed Griggs's Avatar
Default 2000 VW Beetle Cooling Fans
I need help. I cannot get the cooling fans on my 2000 VW Beetle 1.8GLS to come on. I have verified that all fuses are the required ratings and that they are in fact ok (tested with OHM Meter). With advise from several "mechanics", I have replaced the Fan Control Module, the sensor on the side of the radiator and the sensor by the inlet. (meaning all sensors have been replaced). The fans tested "good"(they came on}when I took them to the local electric motor guy and have worked (twice) in the car when you ground the sensor on the input (before the "T" that splits off to the electric pump). But I cant get them to run when you turn the A/C on or once the vehicle has been running. Any Ideas??
Old Sep 18, 2015 | 06:37 PM
If you find someone with VAG-COM\VCDS there are more tests you can do.
vitbobrov
Jul 2, 2011 08:37 PM
racerdonnie13
Jun 19, 2011 09:51 AM
hydropkd
Sep 23, 2008 05:02 PM
BARONVONGLOWWORM
Apr 25, 2008 10:23 AM
BARONVONGLOWWORM
Mar 11, 2008 04:58 PM
